17 years ago
error in compiling VHDL CODE
sir, i'm using modelsim for simulating my VHDL code.
When i was simulating, i encountered an error. The error statement was as given below:
Signal "prior_a0" is type ieee.std_logic_1164.std_logic; expecting type ieee.std_logic_1164.std_logic_vector
can u pls help me in trobleshooting this problem..
i'm stuct in between my project because of this error.
kind:)y answer
    sir, the sir is not yet cleared.
    so, i'm senting u the source of my top level entity.
    kinly point out the correction, i will make the corrections
    pls help, i'm an omly a beginner in this design:confused:
    ----AUTOPILOT TRANSPORT SYSTEM - TOP LEVEL ENTITY----------
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    use ieee.numeric_std.all;
    use ieee.std_logic_unsigned.all;
    entity ats_top is
    port( reset: in std_logic;
    clk : in std_logic;
    IrC : in std_logic;
    IrL : in std_logic;
    IrR : in std_logic;
    c : in std_logic_vector(3 downto 0);
    l : out std_logic_vector(3 downto 0);
    r: out std_logic_vector(3 downto 0);
    g: out std_logic_vector(7 downto 0));
    end ats_top;
    architecture arc_ats_top of ats_top is
    --signal clk: std_logic;
    signal rst_a0: std_logic;
    signal rst_a1: std_logic;
    signal rst_a2: std_logic;
    signal rst_a3: std_logic;
    signal rst_x: std_logic_vector(1 downto 0);
    signal rst_e: std_logic;
    signal rst_lp: std_logic;
    signal rst_c: std_logic_vector(3 downto 0);
    signal rst_r: std_logic_vector(3 downto 0);
    signal rst_l: std_logic_vector(3 downto 0);
    signal rst_p: std_logic_vector(3 downto 0);
    --signal rst_output: std_logic_vector(3 downto 0);
    signal manual_c:std_logic_vector(3 downto 0);
    signal manual_r:std_logic_vector(3 downto 0);
    signal manual_l:std_logic_vector(3 downto 0);
    signal manual_m:std_logic;
    --signal manual_output:std_logic;
    --signal prior_call_rst:std_logic;
    signal prior_a0:std_logic;
    signal prior_a1:std_logic;
    signal prior_a2:std_logic;
    signal prior_a3:std_logic;
    signal prior_e:std_logic;
    --signal prior_m:std_logic;
    signal prior_s:std_logic;
    signal prior_c:std_logic_vector(3 downto 0);
    --signal prior_call_output: std_logic;
    signal lead_user_rst:std_logic;
    --signal lead_user_a0:std_logic;
    --signal lead_user_a1:std_logic;
    --signal lead_user_a2:std_logic;
    --signal lead_user_a3:std_logic;
    --signal lead_user_e:std_logic;
    --signal lead_user_s:std_logic;
    signal lead_user_output:std_logic_vector(1 downto 0);
    signal lead_user_c:std_logic_vector(3 downto 0);
    --signal lead_user_output: std_logic_vector(1 downto 0);
    --signal map_route_rst: std_logic;
    signal map_route_x: std_logic_vector(1 downto 0);
    signal map_route_p: std_logic_vector(3 downto 0);
    --signal map_route_output: std_logic_vector(3 downto 0);
    --signal path_with_obstacle_rst: std_logic;
    signal path_with_obstacle_lp: std_logic;
    signal path_with_obstacle_p: std_logic_vector(3 downto 0);
    signal path_with_obstacle_IrC: std_logic;
    signal path_with_obstacle_IrL: std_logic;
    signal path_with_obstacle_IrR: std_logic;
    signal path_with_obstacle_a0: std_logic;
    signal path_with_obstacle_a1: std_logic;
    signal path_with_obstacle_a2: std_logic;
    signal path_with_obstacle_a3: std_logic;
    signal path_with_obstacle_s: std_logic;
    signal path_with_obstacle_g: std_logic_vector(7 downto 0);
    signal path_with_obstacle_l: std_logic_vector(3 downto 0);
    signal path_with_obstacle_r: std_logic_vector(3 downto 0);
    --signal path_with_obstacle_output: std_logic_vector(3 downto 0);
    --component system_clock
    -- port(reset:in std_logic;
    -- sys_clk: out std_logic);
    --end component;
    component rst
    port(reset: in std_logic;
    a0: out std_logic;
    a1: out std_logic;
    a2: out std_logic;
    a3: out std_logic;
    e: out std_logic;
    s: out std_logic;
    lp: out std_logic;
    m: out std_logic;
    x: out std_logic_vector(1 downto 0);
    c: out std_logic_vector(3 downto 0);
    l: out std_logic_vector(3 downto 0);
    p: out std_logic_vector(3 downto 0));
    end component;
    component manual
    port(c:in std_logic_vector(3 downto 0);
    r:out std_logic_vector(3 downto 0);
    l:out std_logic_vector(3 downto 0);
    m: out std_logic);
    end component;
    component prior
    port(c: in std_logic_vector(3 downto 0);
    m: in std_logic;
    a0: out std_logic;
    a1: out std_logic;
    a2: out std_logic;
    a3: out std_logic;
    e: out std_logic);
    end component;
    component lead_user
    a0: in std_logic_vector(8 : 4);
    a1: in std_logic_vector(8 : 4);
    a2: in std_logic_vector(8 : 4);
    a3: in std_logic_vector(8 : 4);
    e: in std_logic;
    s: in std_logic;
    x: out std_logic_vector(1 downto 0));
    end component;
    component map_route
    port(clk: in std_logic;
    reset:in std_logic;
    x: in std_logic_vector(1 downto 0);
    p: out std_logic_vector( 3 downto 0));
    end component;
    component path_with_obstacle
    clk: in std_logic;
    lp: in std_logic;
    IrC: in std_logic;
    IrL: in std_logic;
    IrR: in std_logic;
    p: in std_logic_vector(3 downto 0);
    s: out std_logic;
    a0: out std_logic;
    a1: out std_logic;
    a2: out std_logic;
    a3: out std_logic;
    end component;
    begin
    lead_user_c <= prior_c;
    --lead_user_a0 <= prior_a0;
    --lead_user_a1 <= prior_a1;
    --lead_user_a2 <= prior_a2;
    --lead_user_a3 <= prior_a3;
    -- lead_user_e <= prior_e;
    --lead_user_s <= path_with_obstacle_s;
    map_route_x <= lead_user_output;
    path_with_obstacle_p <= map_route_p;
    prior_a0 <= path_with_obstacle_a0;
    prior_a1 <= path_with_obstacle_a1;
    prior_a2 <= path_with_obstacle_a2;
    prior_a3 <= path_with_obstacle_a3;
    prior_s <= path_with_obstacle_s;
    -- syc : system_clock port map(reset,sys_clk);
    rest: rst port map(clk,rst_a0,rst_a1,rst_a2,rst_a3);
    man : manual port map(manual_l,manual_r,manual_c);
    pri : prior port map(prior_c,prior_a0,prior_a1,prior_a2,prior_a3,prior_e);
    lead : lead_user port map(prior_a0,prior_a1,prior_a2,prior_a3, prior_e,prior_s,lead_user_c,lead_user_output);
    mapr : map_route port map(clk,lead_user_output,map_route_p);
    motor : path_with_obstacle port map(clk,map_route_p,path_with_obstacle_lp,path_with_obstacle_IrC,path_with_obstacle_IrL,path_with_obstacle_IrR,path_with_obstacle_r,path_with_obstacle_l,path_with_obstacle_a0,path_with_obstacle_a1,path_with_obstacle_a2,path_with_obstacle_a3,path_with_obstacle_s,path_with_obstacle_g);
    end arc_ats_top;
    ur signal is of more than one bit.....so u have to define it as
    STD_LOGIC_VECTOR(max:min);
    no, sir. this error was encountered when i was moulding the top level entity
