ERROR: Illegal panel id: -1. Specify a legal panel id
Getting an error building a bitfile for a 5SGXEABN2F45I2 fpga, using Version 16.0.1 Build 218 06/01/2016 Patches 1.06 SJ Standard Edition. The error is:
ERROR: Illegal panel id: -1. Specify a legal panel id.
while executing
"write_report_panel -file Report_Fmax_Summary.txt -id $id_panel_fmax"
(file "reportPanel.tcl" line 19)
Report file does not exist in run_678
No runs for PROJECT=cerberus
- SyafieqS
We do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- SyafieqS
May I know if there is any update?
- SyafieqS
Is this error related to timing?
I can see you are using custom tcl to report timing, and seem there is issue with the panel id no valid or something (which I'm not sure what it is)
- sstrell
Where are you seeing this? That looks like an issue with the timing analyzer not being able to display a report instead of a Quartus compilation error.
