EDICHARA
5 years agoError: HSSI PMA TX Buffer node after signaltap
Hello World, I have a project that compiles without errors, and the project is work. But when I add certain signals (the output signals of the transmitter created with the "Arria V Transceiver Native...
Deshi_Intel
5 years agoHi,
You can't use signal_tap to probe on hard circuit block like TX PMA buffer. That's why you can error message.
Signal_tap can only be used to probe on interface bus that connect to FPGA core logic only.
- For Eg : tx_parrallel_data bus or rx_parrallel_data from NativePHY IP
dlim
EDICHARA
5 years agoThanks.
