Moti's avatar
Moti
5 years ago
Error fitter for PHY IP gen3
Hi All, I use Stratix10, quartus pro 20.3, I want to generate IP PHY of PCIe, gen3 configuration.(Single lane) the fitter reports the following error: Error (15653): The Fitter cannot find ...
  • Deshi_Intel's avatar
    5 years ago
    HI,
    You are right. Your FPGA pin assignment setting is fine.
    The problem is on your top level design connection. Below is the fix I made to your vqm design
    1. Fixed broken NativePHY (tx_serial_data) connection
    • I presume you want to connect to output port "DIFF100_PCIE_MOLEX_1KU12_PET" so I connect it back
    1. Fixed wrong clocking connection to NativePHY for PIPE GEN 3
    • fPLL tx_serial_clk should be connected to NativepHY tx_serial_clk0
      • ATX PLL tx_serial_clk should be connected to NativepHY tx_serial_clk1
    You can also generate the example design directly from NativePHY IP to learn about the design connection
    • Goto NativePHY -> design example tab
      • change the fPLL default frequency from 125MHz back to 100MHz
      • Then click generate example design button
    dlim
