18 years agoError error error...IDE
"The software settings (STF) file associated with this project is damaged. This may be fixed by copying your source files into a new C/C++ application project. For more details see the error log." T...
18 years agoI've had the same problem. My solution was to create a new project at another directory. A precaution I used was to avoid spaces in paths. Probably silly but if nothing else works it is worth a try.
Best Regards, Ola Bångdahl
