9 years agoError! Connected system ID hash not found on target at expected base address!
When I run the Nios II Hardware, there is an error "Connected system ID hash not found on target at expected base address" When I click System ID Properties I get: expected system id base addres...
9 years agoCan you write your NIOS CPU settings? From where program code is running ect? Have you tried to recompile your project?
- Regenerate your QSYS system.
- Recompile your project.
- Rebuild NIOS BSP settings
- Rebuild NIOS software
- Make memory initialization file
- Program .sof file
- Try to run NIOS
