9 years agoError! Connected system ID hash not found on target at expected base address!
When I run the Nios II Hardware, there is an error "Connected system ID hash not found on target at expected base address" When I click System ID Properties I get: expected system id base addres...
9 years ago --- Quote Start --- Hi, What board or FPGA are you using? I think you are trying to run NIOS II program from FPGA which is not programmed with correct bitstream. --- Quote End --- Thank you for your help! The board is designed by myself,the FPGA is Ep4ce40f23i7. The same program is OK in other board, I'm sure the program and my operation is right , but there is no systemID ,and When I use System Console ,it shows com.altera.systemconsole.internal.plugin.jtag.oci. Nios2DebugException: Target is broken and needs to be reset while executing I'm sure I download the right .sof file,I thought the FPGA is broken. But I run other program without nios, FPGA runs OK.Is the any other possible issue?
