9 years agoError! Connected system ID hash not found on target at expected base address!
When I run the Nios II Hardware, there is an error "Connected system ID hash not found on target at expected base address" When I click System ID Properties I get: expected system id base addres...
9 years agoHi,
What board or FPGA are you using? I think you are trying to run NIOS II program from FPGA which is not programmed with correct bitstream.
