15 years ago
error: can't defined "/" operator
Hello everyone,
Here is my code where I want to add two values of a vector. For example, I have a vector (3,4) and I want to do like this;
(3+4)/2;
Package my_data_types is
Type vector is array (1 downto 0) of integer;
Type vector_next is array (0 downto 0) of integer;
End my_data_types;
LIBRARY ieee;
USE ieee.ALL;
USE work.my_data_types.all;
ENTITY adddiv IS
PORT (
Ra : IN vector;
clk : IN bit;
A : OUT vector_next
END adddiv;
ARCHITECTURE adddiv OF adddiv IS
BEGIN
Process(clk)
variable temp: vector_next;
BEGIN
If clk'event and clk = '1' Then
temp := ((Ra(0) + Ra(1))/2);
End if;
A <= temp(0 downto 0) after 20ns;
END PROCESS;
END adddiv;
But, this error occur:
Error (10327): VHDL error at adddiv.vhd(24): can't determine definition of operator ""/"" -- found 0 possible definitions
Can anyone help me..many thanks
    the problem is because there is no "/" operator for the vector_next type. try this instead:
    temp(0) := ((Ra(0) + Ra(1))/2);
    O also assume this is just a model, because
    is not synthesisable - the delay will be ignored when you compile.
