17 years ago
Error: Cannot drive signal 'data' of mode IN
I am new user to ModelSim and writing VHDL code..
I've got the follwing msg when I compiled a vhdl code
"Error controller.vhd(64): Cannot drive signal 'data' of mode IN."
First, I want to to know where could I find a place to read about compiler error messages ..
Second, I didn't understand what this error means?
I have the follwing declarations in my code
constant instruction_size :integer:=10;
constant operation_size :integer:=4;
subtype command_word is unsigned(operation_size-1 downto 0);
subtype program_word is unsigned(instruction_size-1 downto 0);
data : in program_word; -- in the entity of the controller
--the follwing in the structure of the controller
alias command: command_word is data (instruction_size-1 downto 6);
signal instr : program_word ;
type state_type is (S0, S1, S2, S3, S4, S5, S6, S7, S8);
signal state: state_type;
Then I have this piece of code
case state is
when S2 => instr<=data; -- Load instruction
state <= S3;
when S3 => command <= instr (instruction_size-1 downto 6);
when I compile this file I got the above mentioned error msg on the last line of code above, i.e " when S3 => ...."
I am looking forward to get some help with this problem..
Thank you in advance
    Thank you Fvm for your answer,
    I discovered that I had missunderstod how to use aliased signals.
    I corrected it and all the things are ok now.
    If I understand right, you are trying to assign a value to a port signal of IN type. This isn't possible by basic VHDL rules - and can't create a meaningful logic behaviour, to my opinion. A signal can either be driven externally or from internal logic. If the signal source is intended to be changed during operation, a multiplexer would be necessary.
