8 years agoError (209014): CONF_DONE pin failed to go high in device
Hi, When i want to flash Stratix V board with SOF file i get this error. How can i ground Chip Enable pins? i did it in my verilog code like 1'b0 ,but it did not work. how can we ground them ph...
8 years agoHi,
--- Quote Start --- When i want to flash Stratix V board with SOF file i get this error. How can i ground Chip Enable pins? i did it in my verilog code like 1'b0 ,but it did not work. how can we ground them physically? --- Quote End --- It is a power issue. Do you mean nce(chip enable) pin not connected to ground? Then you need to have hardware modification. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
