11 years agoError 170084 ADC & PLL
Given: Quartus 14.1.1 build190 BeMicro Max 10 10M08DAF484 System clock on N14 Error (170084): Can't route signal "ADC06:inst|ADC06_altpll_0:altpll_0|ADC06_altpll_0_altpll_5q22:sd1|wire_pll...
11 years agoThe Qsys pictures below better describes the problem. If I attach the system clock pin to N14 I must add a second altpll (altpll_1) or the compiler will fail in fitter. If I attach the system clock pin to N9 then I can use a single altpll (altpll_0) and compile without errors.
I am wondering why fitter cannot connect to N14 with a single altpll. https://www.alteraforum.com/forum/attachment.php?attachmentid=10213 2 altpll https://www.alteraforum.com/forum/attachment.php?attachmentid=10214 1 altpll Mike
