AlexBarry
2 years agoError 169182 with Cyclone 10 LP
I am compiling a design for the Cylcone 10 LP (10CL025YE144I7G). We use using active serial configuration mode. Currently, we have a 3.3V LVCMOS output signal on pin 11. When I added the serial fl...
- 2 years ago
why do you need SFL integrated with application code. Standard solution would be default SFL image loaded by programmer, it doesn't conflict with any application pin assignments.
AqidAyman_Altera
2 years agoAlexBarry
2 years agoThat solution builds fine. We were hoping to have an in-system update capability that would not pause application functionality, but that's just a desired feature, not a hard requirement.
