alex100
2 years agoError (16021) using 10M08SCE144C8G
I'm utilizing the MAX10 FPGA, specifically the 10M08SCE144C8G model, to generate sweeping sinewave signals using lookup tables and multipliers. However, during compilation, I encountered the following error message:
"Error (16021): You specified a configuration mode that includes memory initialization, however memory initialization is not supported by the selected device. In the Device and Pin Options dialog box, choose a configuration mode without memory initialization."
I attempted to address this issue by making adjustments in Assignments -> Device and Pin Options -> Configuration mode. Unfortunately, choosing either of the options led to the same error. I'm seeking assistance to resolve this issue. Thank you in advance.
