Error (16021) using 10M08SCE144C8G
- What is the setting when compiling those 2 devices? Is there any differences? (Compilation setting)
- Please also share the compilation report for 10M016SCE144C8G.
- Can you share your design in .qar?
Aiman
- alex1002 years ago
Hi NurAiman,1. I'm a bit uncertain about what you're referring to with '(Compilation Setting)'. The only alteration I made was within the 'Device and Pin Option' where I set the Configuration to 'Single Uncompressed Image (256Kbits UFM)' for both chips.
2. This is the flow Summary (using 10M16SCE144C8G) after compiling:
Flow Status Successful - Wed Feb 21 09:48:40 2024
Quartus Prime Version 21.1.1 Build 850 06/23/2022 SJ Lite Edition
Revision Name Ramp50M
Top-level Entity Name Ramp50M
Family MAX 10
Device 10M16SCE144C8G
Timing Models Final
Total logic elements 7,786 / 15,840 ( 49 % )
Total registers 1088
Total pins 32 / 101 ( 32 % )
Total virtual pins 0
Total memory bits 0 / 562,176 ( 0 % )
Embedded Multiplier 9-bit elements 90 / 90 ( 100 % )
Total PLLs 0 / 1 ( 0 % )
UFM blocks 0 / 1 ( 0 % )
ADC blocks 0-----------------------------------"
3. I'm unsure about creating a .qar file. Could you guide me through the steps to make one?
