AKAYA's avatar
AKAYA
7 years ago
Error (12002): Port "I2C_SCL" does not exist in macrofunction "U1"
AM GETTING THIS ERROR WHILE ANALYSINING THE DESIGN
CAN SOMEONE SUGGEST WHAT COULD BE THE PROBLEM...
I have checked the qsys also the name are same and i have also exported the pin
THANKS AND REGARDS
  • Hi,
    Here are the possible solution for your issue:
    1. Check the Qsys system to ensure the missing port exists in the design
    2. If you have duplicates or more than one output folder, please remove the unused output folder, the error might be Qsys confused between the output folders.
    Let me know if the problem persist.
    • AKAYA's avatar
      AKAYA
      hi,
      thanks for the reply...
      as you said i checked the missing port but there is a port in the qsys....
      i am attaching the project here... can you please check and let me knw...
      the qsys design is in the RSU floder-> onchip.qsys
      • EBERLAZARE_I_Intel's avatar
        EBERLAZARE_I_Intel
        Is the above manual also reporting the same error?
        If you still facing the error can you do a clean build of the project and share it to me.
