14 years agoError (10533): VHDL Wait Statement error
Hi, I called in a CPRI IP from Altera Quartus II which created a testbench tb_altera_cpri. While trying to compile this testbench I encountered an error: Error (10533): VHDL Wait ...
14 years agohi all;
i have the same problems as sharmakn. while trying to compile project, Quartus II 11.1 Web Edition says: Error (10533): VHDL Wait Statement error at DS_timer.vhd(23): Wait Statement must contain condition clause with UNTIL keyword And this's my code : entity DS_timer is port( clk : in std_logic; start : in std_logic; stop : in std_logic; reset : in std_logic; min : out std_logic_vector(6 downto 0); sec1 : out std_logic_vector(6 downto 0); sec2 : out std_logic_vector(6 downto 0)); end DS_timer; Architecture behavioral of DS_timer is begin process variable temp1 : integer range 0 to 10; variable temp2 : integer range 0 to 6; variable temp3 : integer range 0 to 10; begin wait on reset,clk,start,stop; -- ERROR if (reset='1') then temp1:=0;temp2:=0;temp3:=0; elsif (clk'event and clk='1') then if (start='1') then wait until stop='0'; temp1:=temp1+1; if (temp1=10) then temp1:=0; temp2:=temp2+1; if (temp2=6) then temp2:=0; temp3:=temp3+1; if (temp3=10) then temp3:=0; end if; end if; end if; end if; end if; --7 code segment-- ....................................................................... end behavioral; Am I wrong?Can anyone help? Thanks
