16 years ago
Error 10511 - Arctan
I have receive the message
--- Quote Start ---
Error (10511): VHDL Qualified Expression error at main.vhd(37): ARCTAN type specified in Qualified Expression must match integer type that is implied for expression by context
--- Quote End ---
I'd like to known what type of integer to give it.
Thank.
    Agree with FvM. arctan returns real results, but reals are non-synthesizable constructs in FPGAs. One way is to recast the result back to a synthesizable type, such as integer.
    variable x:real;
    q:=integer(arctan(x));
    You should possibly mention, where the ARCTAN typed definitions comes from. With standard libraries, I'm only aware of the ARCTAN function in IEEE.MATH_REAL, which has a real type argument and result.
    When I click "HELP", I receive
    --- Quote Start ---
    Change the type you specify for an expression to be the same as the implied expression type, or change the context in which the expression occurs so the implied expression type is the same as the type you specify.
    --- Quote End ---
    Right click on the message and click "Help". What does it tell you?
    Jake
