12 years agoError - AXI Master BFM: mgc_axi_slave.sv not supported for Quantum synthesis
I am currently trying to instantiate HPS as prescribed in the document: av_5v4_08.pdf from Altera. I attached AXI Master and Slave BFMs to the f2h, h2f and lw interfaces. And when I try to generate simulation, testbench and synthesis in qsys, the error as in the title of this post occurs. It points at mgc_axi_slave.sv which is not supported for Quantum synthesis, only for Verilog simulation or VHDL simulation. I find this problematic since I also found the file mgc_axi_slave.sv in the GHRD example but the latter succeeds generating simulation, testbench and synthesis. Any help, comment, suggestion pertaining to the proper use of the AXI BFMs will be much appreciated. Thanks, MartinNo RepliesBe the first to reply
