Erasing a Volatile Key from Arria-10 GX
- 2 years ago
Yes, that was my original question and the goal.
Ad 1. I've recently received some info on this subject from one of the FAE's, that's very much under NDA, regarding the use of the internal JTAG in the discussed topic. I hope I won't violate the NDA by saying this: It's not impossible.
Ad 2. That's a very good point. Removing the VCCBAT indeed causes the POR and needs to be extended by external logic, i.e. a monoflip. Having an external security controller, it's easy to implement.
That solves my question. Thank You a lot!
Pawel
I am confirming this with our internal team.
Can I know if you enable Tamper-Protection bit? And do you intended to reprogram the volatile key?
Aiman
- PawelMa2 years ago
No, we did not enable the Tamper-Protection bit. I used the word "tamper" for the mechanical tampering with the device's enclosure.
In our case, it will be sufficient to erase the volatile key.
If it couldn't be done without programming a new one, we can do the full reprogramming cycle.
Pawel
