9 years agoerased MAX10, I/Os condition
hello. I have a design that use MAX10. i noticed that every time I flash it, many I/Os (if not all of them) are going high, according to the documents, the pins should be tri-stated. so first qu...
9 years agoAll unused pins will show the state defined under Assignments/Device/Device and Pin Options/Unused Pins, which is by default "Tri-stated with weak pull-up".
There should be no unused IO pins with different behavior.
