14 years ago
Erase Flash EPCS16 Bemicro
I have a problem to reset the ECPS Flash on Bemicro.
I programmed the Bemicro's flash (ECPS16N) with Nios II Flash programmer. Once the flash is programmed, the orange les is always on.
Now I need to erase the flash.
I tried to reprogram the BeMicro with a new code through Quartus and I get the following message:
"Error : Can't access JTAG chain
Error: Operation failed"
Even the overwriting the flash by a new code, with the Nios II Flash programmer does not help. When I download the .SOPCINFO file, the folowing message appears:
"No Nios II target connection paths were located. Check connections ant that a Nios II.sof is downloaded"
Please help.
PS : I use Quartus II 9.1sp2 and Nios II
