16 years ago
erase failed at offset
Hi all,
I m programming EPCS64 through NIOS-II flash programmer (Cyclone III FPGA). The file i m trying to download into EPCS64 is of size 4 Mega Byte. And we are giving offset at 0x400000. But it is not able to program the EPCS64 device. We tried by changing offset also, but its not working. It is giving error
# !/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd E:/TONE/hello_world_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="E:/TONE/TONE.sof" --output="TONE
.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=TONE.
opt E:/TONE/TONE.sof TONE.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 77 megabytes
Info: Processing ended: Mon Aug 23 10:03:04 2010
Info: Elapsed time: 00:00:10
Info: Total CPU time (on all processors): 00:00:08
Info: Command: quartus_cpf --no_banner --convert TONE.pof TONE.rpd
Info: Peak virtual memory: 73 megabytes
Info: Processing ended: Mon Aug 23 10:03:16 2010
Info: Elapsed time: 00:00:09
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00041800 --cable='U
SB-Blaster [USB-0]' "TONE.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00020000 : Verifying existing contents
00030000 : Verifying existing contents
00040000 : Verifying existing contents
00050000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
00020000 : Reading existing contents
00030000 : Reading existing contents
00040000 : Reading existing contents
00050000 : Reading existing contents
Checksummed/read 19kB in 0.7s
00000000 ( 0%): Erasing
00010000 (16%): Erasing
00020000 (33%): Erasing
Erase failed at offset 20000
Leaving target processor paused
# Creating .flash file for the datafile
"$SOPC_KIT_NIOS2/bin/bin2flash" --base=0x00041800 --location=0x400000 --input="E
:/TONE/toneann.dat" --output="toneann.flash"
# Programming flash with the datafile
SB-Blaster [USB-0]' "toneann.flash"
00400000 : Verifying existing contents
00410000 : Verifying existing contents
00420000 : Verifying existing contents
00790000 : Verifying existing contents
007A0000 : Verifying existing contents
007B0000 : Verifying existing contents
007C0000 : Verifying existing contents
007D0000 : Verifying existing contents
007E0000 : Verifying existing contents
007F0000 : Verifying existing contents
00400000 : Reading existing contents
00410000 : Reading existing contents
00420000 : Reading existing contents
00790000 : Reading existing contents
007A0000 : Reading existing contents
007B0000 : Reading existing contents
007C0000 : Reading existing contents
007D0000 : Reading existing contents
007E0000 : Reading existing contents
007F0000 : Reading existing contents
Checksums took 0.0s
00400000 ( 0%): Erasing
00410000 ( 1%): Erasing
00420000 ( 3%): Erasing
00430000 ( 4%): Erasing
00440000 ( 6%): Erasing
00450000 ( 7%): Erasing
00460000 ( 9%): Erasing
Erase failed at offset 460000
    I have the same problem. ajay_106 and isue, could you be a little more specific, please?
    Is TCLK the 1st pin of JTAG or DCLK pin of EPCS device?
    If it is the 1st pin of JTAG, namely TCK, it should be pulldown to the GND, not pullup.
    ajay_106 said TCLK pullup resistance was changed. Is it correct?
    Thanks a lot for your post. I had exactly the same problem and now it's working with 220 ohm.
    My prbm is solved by changing the value of resister from 1k to 240 ohm.
