16 years agoEPCS4 controller problem
Hello, every one I'm using an Altera FPGA on my board. It is EP2C8Q208C7. I was programming my board using the .jic file with EPCS4 when the power was interrupted. Apter restarted my board, ...
16 years ago --- Quote Start --- Before you try anything else, you need to be able to successfully program the FPGA via JTAG. Focus on that first. Jake --- Quote End --- Thanks for your reply, I will try to program the Cyclone with JTAG. However, hope that there will be some solution for this problem, because in my place, the power are interrupted very often. Hai Au.
