16 years agoEPCS4 controller problem
Hello, every one I'm using an Altera FPGA on my board. It is EP2C8Q208C7. I was programming my board using the .jic file with EPCS4 when the power was interrupted. Apter restarted my board, ...
16 years agoAre you still able to program the Cyclone device via JTAG. Also, when using the JIC method, you must make sure you've checked the Cyclone to be programmed in addition to the EPCS device. The Quartus programmer will first load the "flash loader IP" into the Cyclone device, then it will download the configuration into the EPCS via the Cyclone.
Jake
