9 years ago
EPCS128 Programming
i want to program epcs128 via jtag
what should i do?
    yes you can use another brand but not all of them
    you should disable id check when you want to programm
    also you can use microcontroller for programming
    --- Quote Start ---
    all my problem is related to power design i use tps54310
    my program file is to big and i need the epcs128
    i design DRM
    --- Quote End ---
    I mean that you can select other company's part instead of altera's, which has same memory sizes.
    --- Quote Start ---
    What's the problem you met? And how did u deal with it?
    Do u think you can use other chip to replace epcs128 to save cost? EPCS128 is too expensive.
    --- Quote End ---
    i design DRM
    --- Quote Start ---
    i find my problem if anyone have problem like me can contact me
    email:[email protected]
    --- Quote End ---
    i find problem my problem is power
    now i fixed but i now another problem
    when i programm sof file everything is ok
    but when i programm jic file nothing happend (jic file programm and reach to 100%)
    (i read Configuration, Design Security, and Remote System Upgrades in Cyclone V" chapter from Cyclone V handbook)
    What error message you get when it fails?
    I recomend reading "Configuration, Design Security, and Remote System Upgrades in Cyclone V" chapter from Cyclone V handbook.
    i design my own board
    i use cylcon v 5ceba9f23c8
    i programming fpga via jtag (its work but very slowly)
    after that i convert sof file to jic and start to programming when the programming reach 97%
    its failed !!!
    What board you are using?
    You can use .jic file and USB blaster cable. Go to File-> Convert Programming File. Convert your .sof file to .jic.
