17 years agoEPCS configuration tactics
Hello, I hope somebody can help me. I have the Nios II kit with Cyclone II - EP2C35. And the board contains the EPCS64 device. I want to configure the EPCS device with my design using ...
17 years agoif you wanna program using POF, u have to connect your programmer cable directly into the EPCS device. then set the mode to ACTIVE SERIAL in programmer window. after that you can add the pof file and start programming the EPCS device.
