SSenn
6 years agoEPCQL1024 doesn't response anymore, only with 0xFF
Hi, I have a critical Problem with an Intel EPCQ-L Serial Configuration Device. When I try to configure the EPCQL via the "JTAG indirect configure" feature (JIC file), the EPCQL only returns 0xFF ...
YuanLi_S_Intel
6 years agoHi Sebastian,
There is no way to reset it with special setup or command. You can perform DIE erase only if you are able to connect with the flash.
Thank You.
