SSenn
6 years agoEPCQL1024 doesn't response anymore, only with 0xFF
Hi, I have a critical Problem with an Intel EPCQ-L Serial Configuration Device. When I try to configure the EPCQL via the "JTAG indirect configure" feature (JIC file), the EPCQL only returns 0xFF ...
SSenn
6 years agoFirst of all many thanks to YL_Intel and ak6dn.
Today we saw the same error on a second board in a completely different test setup (but the same type of board). Therefore I would say that it isn't a broken IC. OK, maybe both boards are broken but this is very unlikely.
I'm in touch with the manufacturer, but he is assuming there is a software problem.
Is it possible to reset the EPCQL with a special command? I haven't found anything like this in the datasheet yet.
