17 years ago
EPC16 does not configure EP2C35 at high temperature
Folks,
I have been debugging this issue where the EPC16 device I use does not configure the EP2C35 (Cyclone II) device - at slightly high temperature. I can make it configure by cooling down both devices using freeze spray. :confused:
This is the most fascinating and ridiculous part of the problem - how could the temperature be influencing the basic config cycle??
I am using the Passive Serial mode of configuration. The programming files are proven good. I see the nCONFIG going high followed shortly by nSTATUS and after that ... nothing. The DCLK/DATA0 lines are flatlined (DATA0 continues to remain high and DCLK continues to remain low). Obviously in this case, the CONF_DONE signal does not go high at all.
See waveforms below -
Ch1 – Yellow – nCONFIG
Ch2 – Blue – nSTATUS
Ch3 – Purple – CONF_DONE
Ch4 – Green – INIT_DONE
This is a bad config cycle.
http://i41.tinypic.com/23ib0pl.jpg
On a good config cycle (same board, freezing cold ICs)...
http://i43.tinypic.com/1evt07.jpg
I verified the power up sequence - the VCCIO (3.3V) powers up first (t0). The FPGA-VCCINT (1.2V) powers up at (t0 + 69.2ms). The EPC16 is set to have a POR of 100ms. So I am assuming this powers up at (t0 + 100ms).
This meets the spec.
I have tried 1K & 10K pullups on the INIT_CONF signal with no luck.
I am seeing this on 4-5 of 30 boards. On some boards the issue is a lot more aggravated than the others. One board in particular fails at room temperature. Other boards only seem to fail @ 45-55C.
I have checked to verify that the EPC16 is revC silicon.
Any ideas??
    According to the waveforms, the EPC16 is simply not starting configuration after nSTATUS is deasserted. So I guess, the problem is related to this device rather than the FPGA. The reason for configuration failure can't be explained from the shown waveforms, I think. But it may be probably caused by other EPS16 signals, e. g. an incorrect terminated TCK.
    --- Quote Start ---
    What does the timing of dclk and data0 look like at the fpga?
    --- Quote End ---
    During a bad cycle, the DCLK and DATA0 are dead - flatlined.
    During a good config cycle - they look reasonable enough. I will try to capture a waveform and post it. The CycloneII and EPC device are only a couple of inches apart.
