17 years agoEPC16 does not configure EP2C35 at high temperature
Folks, I have been debugging this issue where the EPC16 device I use does not configure the EP2C35 (Cyclone II) device - at slightly high temperature. I can make it configure by cooling down bo...
17 years ago --- Quote Start --- What does the timing of dclk and data0 look like at the fpga? --- Quote End --- During a bad cycle, the DCLK and DATA0 are dead - flatlined. During a good config cycle - they look reasonable enough. I will try to capture a waveform and post it. The CycloneII and EPC device are only a couple of inches apart.
