16 years agoep610 partnumber decode
I have an equipment spec that alls out the following: EP610ILI-12 EP610LI-20 What is the definition for the "Is" and the "L" Thanks
16 years ago --- Quote Start --- I pulled up an old datasheet, and it didn't have the full part numbering scheme, but here's what I gleamed from ArrowNAC website. [EP610] [l] [-xx] [N] ^ Device family ^ Alternate specs in data sheet. (Maybe a die difference??) ^ PLCC Package L= PLCC P= PDIP D= CDIP ^ Industrial Temp Grade C= Commercial ^ speed grade ^ ROHS compliant if N is present at end of part number --- Quote End --- ;) The first "I" is confusing. It seems to drive to an industrial grade temp to meet the different parametric values. A non first "I" part, but with the second "I", is an idustrial part that has the basic EP610 parametric values, see page 432 of spec. Does that make sense? Al
