PPere22
2 years agoEP4CGX110DF27I7N ISSUA
Customer reported: FRU1 Faulted. The unit booted up correctly, logs were retrieved The unit was vali Date Posted: November 27, 2023 Customer reported: FRU1 Faulted. The unit booted up correctly, logs...
FakhrulA_altera
2 years agoHi Pablo4,
Before we proceed to FA. Can you perform a signal tap on that particular pins? If the ball is damaged during the assembly process Intel would not accept it because it is due to mishandling.
Fakhrul
- PPere222 years ago
Flex doesn't count with infrastructure to perform a Signal Tap. FPGA is bought to the broker Arrow and it arrives already programmed. Talking about mishandling, it is considered not likely due to test coverage: the unit passed all tests in factory, but failed in field. That's the why of 2nd level FA request.
RX evidence attached.
CAAAF2113E
CAAAF2225E
Hi Itel Team, Im waiting for the next step, in ordet to determinate the root cause. pls let me know how proceed.
