11 years agoEP3C16E144 JTAG and AS problem!
The JTAG chain can't be find, but the AS configuration is successful, why? MSEL1 is connected to 2.5V directly, MSEL0 and MSEL2 to GND. nCE is connected to GND directly. TCK is pull down wi...
11 years agoIt all sounds correct. Whilst you've specified the rail sequence Cyclone III will tolerate the rails coming up in any order. So, I can only suggest a build or design fault.
Are you happy all the power and ground pins are connected? You mention the thermal pad - are you happy that's soldered correctly. Cyclone III devices don't work correctly without this pad connected. See this recent thread that discusses it: problem with jtag configuration cyclone iii (http://www.alteraforum.com/forum/showthread.php?t=46656). Cheers, Alex
