19 years agoEP1C3T100C8N FPGA configuration problem
Hi everybody, In my design I use an EP1C3T100C8N cyclone which gets configured from an EPCS1 serial device. EPCS1 is programmed from an external microcontroller that gets the data stream f...
19 years agoAre you sure you converted HEX data into BIN correctly? I'd suggest to use *.RBF file (convert with quartus).
Also, please check bit order when you are programming EEPROM. At least in PS mode, FPGA expects LSB first.
