19 years agoEP1C3T100C8N FPGA configuration problem
Hi everybody, In my design I use an EP1C3T100C8N cyclone which gets configured from an EPCS1 serial device. EPCS1 is programmed from an external microcontroller that gets the data stream f...
19 years agoHi Whitebird,
You can omit suffix 'N' when you specify the device in Quartus II. The 'N' suffix indicate lead-free part. Can you program the EPCS1 device through FPGA's JTAG port using *.jic file? - Just to confirm that support for AS mode is wired correctly on the board. -BD
