Enabling series termination on 1.0V and 3.3V IOs in MAX10 FPGA
In the MAX10 GPIO User Guide, per Table 13. Selectable I/O Standards for RS OCT indicates that On Chip Termination (OCT) is only available for 1.2V thru 3.0V LVCMOS, 1.8V thru 3.0V LVTTL, as well as SSTL and HSTL outputs. Not possible for 1.0V or 3.3V LVCMOS. So you are trying to select an option that is not possible, and Quartus is letting you know that.
Thanks for your input. I have one more question here. What will happen if I declare the IO pins in a bank as 1.2V in the Quartus Pin Planner and connect 1.0V to FPGA VCCIO pins on the board? I will make sure the source and destination IOs are working on 1.0V voltage so that the pins will not get damaged. If this is possible I can enable series termination inside FPGA on the lines I need.
Noujaz
