14 years agoenable/disable interrupt
I am porting a small kernel from avr to nios2 using a DE2 board. I have tried to modify the enable and disable interrupt macro like the follow: # define DISABLE_INTERRUPTS { asm volatile ( "addi r27, r27, -4 \n\t" "stw r3, 0(r27) \n\t" "addi r27, r27, -4 \n\t" "stw r2, 0(r27) \n\t" "movhi r2, 0xFF00 \n\t" "subi r2, r2, 2 \n\t" "rdctl r3, ctl0 \n\t" "and r3, r3, r2 \n\t" "wrctl ctl0, r3 \n\t" "ldw r2, 0(r27) \n\t" "addi r27, r27, 4 \n\t" "ldw r3, 0(r27) \n\t" "addi r27, r27, 4 " ); } # define ENABLE_INTERRUPTS { asm volatile ( "addi r27, r27, -4 \n\t" "stw r3, 0(r27) \n\t" "rdctl r3, ctl0 \n\t" "ori r3, r3, 1 \n\t" "wrctl ctl0, r3 \n\t" "ldw r3, 0(r27) \n\t" "addi r27, r27, 4 " ); } When I try to debug using the hardware, the status register can not be correctly set. But when I use the instruction set simulator, it works fine. Can someone give me some hint. with regards, Wei5 Replies
Context is useful when calling irq enable all to restore interrupt conditions present before calling irq disable all!
--- Quote Start --- you can pass null as the context i think --- Quote End --- I will try that. - Altera_Forum
Hi aprado,
--- Quote Start --- Why don't you use altera's library irq enable and disable? --- Quote End --- I have looked into the provided one. The alt_irq_enable_all need a context, which force me the modify other kernel code. - Altera_Forum
