Enable on-chip termination for Differential Transceiver clocks
- 1 year ago
as far as I understand you are still searching for valid .qsf entry for transceiver clock input termination.
Valid settings are listed in this document: https://www.intel.com/content/www/us/en/docs/programmable/683296/24-3.html
As far as I see, the settings are the same for previous Quartus Pro versions.
The option for transceiver reference clock termination is XCVR_A10_REFCLK_TERM_TRISTATEallowed values are TRISTATE_OFF and TRISTATE_ON
TRISTATE_OFF corresponds to 100 ohm differential termination.
Some confusion is caused by the fact, that Quartus Std. uses a different option name
XCVR_REFCLK_PIN_TERMINATIONvalues are AC_COUPLING, DC_COUPLING_EXTERNAL_RESISTOR and DC_COUPLING_INTERNAL_100_OHMS
See: https://www.intel.com/content/www/us/en/docs/programmable/683084/current/settings-file-reference-manual.html
To check which termination has been actually implemented, you can review QPP fitter report/Plan Stage/Input Pins.
Frank
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
