Enable on-chip termination for Differential Transceiver clocks
- 1 year ago
as far as I understand you are still searching for valid .qsf entry for transceiver clock input termination.
Valid settings are listed in this document: https://www.intel.com/content/www/us/en/docs/programmable/683296/24-3.html
As far as I see, the settings are the same for previous Quartus Pro versions.
The option for transceiver reference clock termination is XCVR_A10_REFCLK_TERM_TRISTATEallowed values are TRISTATE_OFF and TRISTATE_ON
TRISTATE_OFF corresponds to 100 ohm differential termination.
Some confusion is caused by the fact, that Quartus Std. uses a different option name
XCVR_REFCLK_PIN_TERMINATIONvalues are AC_COUPLING, DC_COUPLING_EXTERNAL_RESISTOR and DC_COUPLING_INTERNAL_100_OHMS
See: https://www.intel.com/content/www/us/en/docs/programmable/683084/current/settings-file-reference-manual.html
To check which termination has been actually implemented, you can review QPP fitter report/Plan Stage/Input Pins.
Frank
Hi
For enabling on-chip termination in your Arria 10 transceiver clocks, the correct syntax varies based on whether you’re working with differential inputs or need specific resistance values. Intel typically recommends the following .qsf assignments for Arria 10:
set_instance_assignment -name INPUT_TERMINATION "DIFFERENTIAL 100 OHM" -to clk_xcvr_1 -entity myDesign
This is the preferred method for specifying 100-ohm differential termination on transceiver reference clocks. Make sure your entity name and clock name (clk_xcvr_1 in this example) match your design.
For more information refer: https://www.intel.com/content/www/us/en/docs/programmable/683084/current/xcvr-a10-rx-term-sel.html
- anonimcs2 years ago
Contributor
I can try that for sure, but I don't get that my design works with an invalid syntax for the clock termination. It's a differential clock and 100 ohm internal termination is recommended, so I would expect the things to go wrong when I used the syntax I posted. Could you tell me why ?
Kind regards
