SSilu
6 years agoEMIF link project error
I encounter following error when try to link project to device. I enabled debug toolkit in emif ip. Quartus 19.3. link_project_to_device -device_name {10AX115H1(.|E2|ES)|10AX115H2|..@1#1-2} -hardwa...
Deshi_Intel
6 years agoHI,
Yes, I can see something odd with your ddr_b cal report.
- add[16:14] and par_in pins result are uncalibrated
- Did you see this weird result consistently over multiple ddr_b calibration (with either reseting DDR_b or after power cycle your your board) ?
I suggest you to look into below debug option first
- Have you compare the Quartus design and DDR4 IP setting between ddr_a and ddr_b ? I can help you review as well if you can share with me your Quartus design QAR file
- Also, is there any on board connection difference between ddr_a connectino vs ddr_b connection ? Again, I can help you review if you can share with me you board schematic pdf file
dlim
