8 years agoEMIF example design calibration fail on Stratix10
Hi guys, I'm testing EMIF on Statix 10 DevKit with RLDRAM3 and I'm running into some issues that have been blocking me for more then a week. Here is what I did: I chose a preset "RLDRAM3...
8 years agoDev kits come with complete example designs. You should use that instead of what you generate from the parameter editor. However, on the Example Designs tab of the EMIF parameter editor, is your board listed? Make sure you select your board before generating the example design.
If your board is not listed, use the examples that came with the kit.
