EMIF DDR4 STRATIX 10 ,QUARTUS PRIME PRO 20.1
Hi, I have Generated example design for emif stratix 10 and simulation scripts too. While simulating in the modelsim ,every signal has default values only. even calib_success&fail both were low only!
one more thing ,I have generated emif core. With Avalon bus signal I am trying to feed some data,in this case aslo calibration is not going high.
- VenkateshK
can you please share any emif ddr4 stratix design with model sim scripts whcih are working!
venkatesh k
- VenkateshK
I have created example design and generated simulation scripts from Quartus prime pro then simulated through modelsim ,in model sim local_cal_succes is low only.
Basically how much time does simulation takes to complete caliberation (i have used skip caliberation)?
Appolozies! I am not supposed to share any file!
- AdzimZM_Altera
Hi Sir,
I'm Adzim. Thanks for using Intel Community.
May I have a simulation log from the example design that you have run?
Also, can you share the example design with me?
I want to replicate the issue.
Adzim
