VenkateshK
4 years agoEMIF DDR4 STRATIX 10 ,QUARTUS PRIME PRO 20.1
Hi, I have Generated example design for emif stratix 10 and simulation scripts too. While simulating in the modelsim ,every signal has default values only. even calib_success&fail both were low only...
AdzimZM_Altera
4 years agoHi K Venkatesh,
The Abstract PHY mode, Skip Calibration mode and Full Calibration mode are take action on Simulation.
The design has same structure and can be tested on board.
If you want to observe the design in simulation, then you can choose either Skip Calibration or Full Calibration mode.
Adzim
- VenkateshK4 years ago
Can you please simulate without Abstract phy and share the result ! as well as design!?
I have tried simulation without enabling abstract phy ! but didn't get any thing!
Thankyou.
K venkatesh
Thankyou so much for clarification!
I was trying to Implement EMIF DDR4 .but its not working properly.Here's the few issues- local_calib_success is going high ,immediately the controller(amm_ready) is going to busy state(high).
- after some time loca_calib_success going to low ,immediately emif_user_reset_n is going low
if possible ,could you please share Code for instead of Traffic generator for testing DDR4 instead of Traffic generator
I have attached a snapshot regarding this.
