EMIF DDR4 STRATIX 10 ,QUARTUS PRIME PRO 20.1
Hi Venkatesh,
I'm not able to share the example design for simulation because the size is exceed the limit.
So I would like you to do these:
- Create new EMIF IP in Parameter Editor.
- Generate example design for EMIF IP in the Parameter Editor.
- Go to this path: <example design project directory>/sim/ed_sim/mentor
- Simulate the msim_setup.tcl with Modelsim.
I can share the EMIF IP setting that I've used to so you can generate the example design with the IP.
The waveform and simulation log also included.
Adzim
hi sir,
May I know whwther you have enabled "ABSTRACT PHY " or not?
while restoring the .qar file ,I am getting like this
Error:ERROR: Error(s) found while restoring the archive. See error message(s) for details.
Error: while executing
Error:"project_restore chiptrip.qar"
- AdzimZM_Altera4 years ago
Hi Venkatesh,
Yes, I've enabled the Abstract PHY mode in the project.
You need to generate the example design from the EMIF IP in the project.
I've re-attached the project here.
I hope you can extract it without any error.
Maybe the file was corrupted during the compressing process.
Sorry for any trouble.
Adzim
- VenkateshK4 years ago
I am getting simulation with Enabling "ABSTRACT PHY" option but I want to enable Hard Controller also in design!in this case simulation i am not getting?
K venkatesh
