VenkateshK
4 years agoEMIF DDR4 STRATIX 10 ,QUARTUS PRIME PRO 20.1
Hi, I have Generated example design for emif stratix 10 and simulation scripts too. While simulating in the modelsim ,every signal has default values only. even calib_success&fail both were low only...
VenkateshK
4 years agoYES sir, I did run -all only ,its been more than 2 hours ,still calib_success is low only!
I have been using Stratix 10 EMIF.
in log:
initializing RAM with calibration code ... ed_sim.emif_s10_0.emif_s10_0.arch.arch_inst.io_ssm_inst.io_ssm.inst.<protected> @ 2750 ps
after this empty.
what could be the issue?
Sir,do you have any code for custom data write and read instead of traffic generator?
VenkateshK
4 years agoone more thing sir,
at the end of compilation ,getting critical warning "DDR4 Timing Requirements not met".
In SDC file, I have created clocks for pll_clk and user_clk!
Is problem is related to timing issues?
