EMIF DDR4 STRATIX 10 ,QUARTUS PRIME PRO 20.1
Hi Venkatesh,
I think the time for finishing calibration should be around 30 minutes or more but it's depends on the device that has been used.
Is there any transaction in the log?
I think you need to let the design run -all and finishes the simulation.
It's will give you the result at the end.
Adzim
- VenkateshK4 years ago
YES sir, I did run -all only ,its been more than 2 hours ,still calib_success is low only!
I have been using Stratix 10 EMIF.
in log:
initializing RAM with calibration code ... ed_sim.emif_s10_0.emif_s10_0.arch.arch_inst.io_ssm_inst.io_ssm.inst.<protected> @ 2750 ps
after this empty.
what could be the issue?
Sir,do you have any code for custom data write and read instead of traffic generator?
one more thing sir,
at the end of compilation ,getting critical warning "DDR4 Timing Requirements not met".
In SDC file, I have created clocks for pll_clk and user_clk!
Is problem is related to timing issues?
