VenkateshK
4 years agoEMIF DDR4 STRATIX 10 ,QUARTUS PRIME PRO 20.1
Hi, I have Generated example design for emif stratix 10 and simulation scripts too. While simulating in the modelsim ,every signal has default values only. even calib_success&fail both were low only...
VenkateshK
4 years agoHi sir ,
Thankyou for the reply,
If I do enable Abstract PHY,mem_* signals will not get anything means ,Abstract PHY enables only PHY not Controller! correct?
I Tried with Abstract PHY enable option too, but i didn't get calib_success!
Basically how much time Will take to complete the calibration?
Thanks for run.do file ,but i didn't see any change! still all the signals have default values except pll_clk,usr_clk !
I don't know what the issue is? am not getting output values?
