open01
4 years agoEMIF calibration failure
I use Cyclone 10 GX devices.
Quartus version is 17.1 pro, and use MT25Q Flash device.
I found that when I use the .rpd file of the ASx1, the function of the FPGA after power-on is normal....
AdzimZM_Altera
4 years agoHello,
I hope you're doing well.
May I have any update from your side?
Adzim
- open014 years ago
Hi Adzim,
Thank you for your continued help. I think I found a temporary solution, although I don't know the real problem.
When I change the MSEL setting from fast to normal, the ASx4 configuration will not cause EMIF to fail.
I don't know why POR time is the main reason for this phenomenon, what do you think?
Thanks for your answers.
