open01
4 years agoEMIF calibration failure
I use Cyclone 10 GX devices.
Quartus version is 17.1 pro, and use MT25Q Flash device.
I found that when I use the .rpd file of the ASx1, the function of the FPGA after power-on is normal....
AdzimZM_Altera
4 years agoHi,
Actually the EMIF calibration won't be affected by this configuration.
If you can provide the EMIF Calibration report from the EMIF Debug Toolkit, that would be help.
Adzim
- open014 years ago
Hi Adzim,
Thank you very much for your reply, here is a screenshot of my result,
These two results are the file results converted by the same .sof, one is ASx1 (calibration pass) and the other is ASx4 (Calibration Fail).
In addition, I also tried to set the NVCR, but it does not seem to improve the situation.
Thanks for your answers.
